TampaNate77
- Joined
- Jun 6, 2012
- 117
What else could cause carb to leak besides the needle valve and the float being out of adjustment?
Do only a few drops leak after the motor is off, or does a few oz leak? If a few drops, maybe it is expansion of fuel caused by heat of the motor. If more than that, maybe float/needle are a bit out of adjustment or a bit worn. Any chance the float is twisted or leaks internally?
Nate, It has nothing to do with your reed valves. Is the float made of cork? Sometimes they get loose in the brass clamps. If they are hard plastic, are they cracked or leaking?
If your reeds are bad then you will get blowback through the carb. This is not the carb leaking though
