I have an 89' 2.3L OMC with the 2GC Rochester Carb.
I have gone through the steps to check and verify my remote cable and shift cable adjustments. I wasn't inpressed with the shift cable steps everything seems loose and worn some.
Anyways, I am trying to adjust my Carb Linkage cable and I can not get the exact measurement of 2 3/32 center to center for the linkage.
I have the OMC manual and have read it many times. The best I can get is 1.826 when it should be 2.093, so I am a little over .26 from getting the center to center measurement.
The reason I am messing with it in the first place is two fold:
1) I just like messing with stuff
2) I can not seem to get the idle set right. As in right now the idle screw is not even touching the idle stop and I am still idleing at about 1200rpms.
Is there something I am missing and/or could the OMC manual measurement be wrong ( I hope not its the factory manual)?
Thanks David
Thanks David
