Scallywag1
- Joined
- Sep 5, 2008
- 19
I have a 1989 85hp with a rebuilt powerhead. I'm still running the 1 pint to 5 gal. mixture. I had to adjust the carbs due to bogging. It would run fine at forward idle, but when getting out of the no wake zone it would die. I adjusted the carbs as my clymar manual advised. Set the idle close (no tach). Set all 3 adjustment screws at 3/4/ turn out. Started motor, ok at idle.Turned counterclockwise until rough idle, turned clockwise never achieved rough idle. The mixture screw seated before rough idle. All 3 carbs the same. I set all to 3/4 turn out seems to run good. I have some smoke when running.
Any ideas as to why motor seems to run ok with such a lean mixture? Will the carbs need readjusted when I start to run the 50:1 mixture? Thanks
