Re: Carb Mixture Screw Settings 85 60 HP Merc
You did not indicate your SN, so I am not sure of the design of your particular carbs, However, if they are like the carb in the attached JPG for a 60HP with SN 0G531301 and above, then the only adjustable jets (screws) on the carbs is for idle. The high speed jets are fixed. While adjusting idle jets is important for a smooth idling motor and good acceleration, they would not affect fuel usage much as most fuel is consumed at higher speeds. If you think that the motor is running too rich at higher speeds, your floats may need adjustment or replacement. It is unlikely that your fixed jet sizes are incorrect.
If your high speed jets are adjustable, please note that it has always been my understanding that too rich is better than too lean at high speeds. Too lean at high speeds may cause quick engine failure (pistons, etc.). It is also my understanding that idle jets set too lean are NOT similarly dangerous, just bad for good idle performance.
I hope I got this right and I am not misinforming you. Does anyone else agree or disagree with the above?
