carb pic/ diagram of johnson 60hp needed please
fishfeatures
Hi, can someone help me out here, a motor i'm working on (johnson 60 hp 1990 bj60elesm) has had the carbs robbed (starter also but thats life) from it and i'm a bit stuck on how the fuel lines connect up and how the solenoid primer connects up. I have looked at the manual but can't find anything defininite on how to do this.
I'm hoping a pic or simple drawing might help. I have only ever had single carb motors and this is my first time on a 3 carb one.
fishfeatures
Re: carb pic/ diagram of johnson 60hp needed please
Even a quick sketch will do, please,
fishfeatures
Cheers Cofe,
Ebay pics are going to help somewhat ,
thanks for the reponses..
where would one get the "T" peices or hose connectors , or are they universal and can be bought at most motor accesory places?
EDIT: These are pirated. Please don't post them here.
hidef
You should get the OMC service manual for your model outboard. As the outboard will most likely require a link and sync to be completed. It will save you pile of frustration and show you everything you need to know to install the carbs and starter.
fishfeatures
Lookupsayaw530 ... Thanks for that link, it should be in a sticky.....
cheers
Hidef , not my outboard only helping a friend out , he lost his and is too miserable and cheap to buy another one...
