carb problem?
bkyser
Hey guys! after almost a year, I finally got my 80hp, Merc 800 running. it's a '69 ser#2881497<br /><br />With your help, I replaced the switchbox, wire harness, rectifier, and stator. (Pretty much everything electrical) I now have great spark, starts and runs at full throttle, but at idle while in gear it wants to stall. it almost sounds like its only running on one carb??? ( when I run it up to full speed, it sounds pretty good. I will switch out anything electrical, but carbs intimidate me. (my experince with them on cars has never gone well) Do you have any suggestions on some easy stuff I could try, before I start removing the carbs? I have the Clymers manual, but it's not really clear on where to start.<br /><br />thanks<br />Bob
greasemonkeyozi
Re: carb problem?
Yeah, did you adjust your float levels according to specs? Did you adjust your jet adjusting screws right? Is your timing right? Check these things and holla.<br /> WOULDNT HURT TO USE SEA FOAM!!! :D :D :D
The Marine Doctor
Re: carb problem?
Carbs for Merc's are straight forward and easy.<br /><br />When you disassemble one..leave the other intact..so you can see how it goes back together.<br /><br />Set the idle screws @ 1 1/2 turns prior to reinstalling.<br /><br />Then start engine and do any fine tuning.<br /><br />TMD
