carb problem
jlwslw
I am new to this forum. Hope someone can help. I have a 1968 evinrude 85 hp, Selectric shift. I am rebuilding the carb. I need to know how to pre-adjust the high and low adjustments. One more question. The kit came with parts I didnt need. The main jets came with the o-rings (I used them) they also came with gaskets to go over the housings that cover the jets, I dont know if it needs them. The carb. didnt have them upon disassembly. I just got this engine and dont know if someone has been in it or not. Any help would be appreciated.
BoatBuoy
Re: carb problem
You can see a parts diagram here: http://epc.brp.com/default.aspx?brands=ej&lang=E
Here are Joe Reeves' suggestions for setting the jets:
(Carburetor Adjustments - Two Adjustable Needle Valves (N/V’s)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
jlwslw
Re: carb problem
I dont see the gasket included in the diagram. I guess it doesnt get used. Thank you for your help.
