Maybe someone can help and thankyou for your help in advance ... When i first start boat it starts normal and it idles around 800 fine,and i leave the dock and run out 30 min i can shut down and restart right away if i want but if i let sit for 10 min or longer it takes like maybe 40sec dont no presice but it should just crank over and run lol ,so i am thinking its the choke and going to check that out but wanted to see what you guys thought.
The motor is a 1990 mercruiser with rochester 2 barrel carb alfa 1 outdrive..
Just put head gaskets in 2 weeks ago and rebuilt the carb..
OTHER THEN MY STARTING PROBLEM WHEN IM OUT IN THE WATER THE BOAT RUNS GREAT
