Carb question...
tnurgeniram
The carberator on my 94' 30hp Evinrude doesn't have an air box or filter. You can see straight to the butterfly valve while it's running. It looks like it has bolt screw holes for this purpose, but I can find the part. Am I searching for a part that doesn't exist? The model number for the engine is E30EERM.
Al-53
Re: Carb question...
I don't think it came with one....Mine has the mounting holes also...but its not a part that came with the motor and not on the parts list either..some models did....its just a air box is all..no filter....it just silenced it a bit is all.....
Al
tnurgeniram
Al
Does yours get some fuel splatter in the bottom of the motor housing?
Al-53
yes just a very very little..it may be from when I use the power tilt at he end of the day to trailer it...but whats there is very very little....I was told also that when stored in sun the gas can expand some and some may drip....
i have seen others with same thing....there is no spray on the cowl or nothing....just a drip is all...
Al
tnurgeniram
Al
Mine has A LOT. It's even spraying the foam in the cowl. Do you know what causes this? I know I'm running rich right now. I need a carb adjustment for sure.
F_R
If it is a LOT, you must have a reeds problem.
