Carb rebuild / clean
orbitz
I was going to attempt to rebuild / clean out the carb in my 94 Bayliner Capri tonight and wondered if anyone had any suggestions or concerns beforehand. Engine is a Mercruiser 3.0L Alpha One II. Anything I should watch for when cleaning / rebuilding?
sethjon
Re: Carb rebuild / clean
Nothing special about it if you've done it before.
TiredoleBoy
Yep be sure to bow out all the passage ways with high pressure air to dislodge any possible dirt.
sltintexas
I just rebuilt mine on a 1996 merc 3.0. I am assuming that since you are asking that you haven't done it before. I hadn't either.
Take your time, take some pictures. the parts I had a hard time remember was the linkages on the outside. I didn't take as good of pics as I should have.
Pay attention to what size gaskets come off as you may get a lot of ones you don't need in a carb kit.
Make sure you have some good screwdrivers. My carb had phillips head screws that were painted over, they were kind of tough to get off with out a properly sized screw driver.
I had a hard time getting the main jets & needle seat out. I guess since they had been in there over 10 years they were in there really good. Again, a really wide screwdriver was needed. I almost stripped the main jet out trying to get it out.
Measure your float drops carefully.
The carb adjustments also gave me a little bit of hassle. It took me a few times out to fine tune it. I finally got some good advice on here and it runs awesome now. here is the link to my post on it http://forums.iboats.com/showthread.php?t=415919
I assume you have the manual. I wouldn't have been able to do it with out it.
myoldboat2
I thought about doing my own a few years ago. Ordered the kit, when it came I looked at all those teeny pieces, looked at my fat fingers, then used them to pick up the phone and call a carb shop. They rebuilt it for about 150 bucks. Had it back in a few days. Bolted it on and used a vacuum gauge to fine tune the needle screws. I prefer doing my own repairs and maintenance, but rebuilding a carb isn't a job for these hands. And it doesn't cost much if you can find a carb shop. Unfortunately, I've seen three carb shops go under in the last year with this great economy we've got going.
