Carb rebuild confusion
bellybuster
Got a 1995 force 120hp that is bogging down bad. Changed plugs, changed fuel filter, bought and installed water seperating fuel filter, had compression tested, changed all the fuel lines I could find, sprayed carbs with deep creep, ran sea foam through entire fuel system, tried removing gas cap while on the water running, tried choking while running, (didnt make a differance!) So I tried disconnecting choke, tried high test fuel, added a octane booster, tried sea foam in the main tank,......all for nothing!!! figure I will rebuild Carbs before I start to check the electrical system. Here's my problem now!! First my engine has 2 carbs, so do I need to buy 2 rebuild kits?, Do I need to buy a gasket kit also? (or does that come with the rebuild kit?), And do I need to buy a needle and seat too(or does that come with the kit?)? Also I am having trouble with the part number? I've been told I need NAPA part # 18-7037 but that did not cross to the Mercury part number FK10103-2 according the the NAPA manager and his catalog. According to his catalog 18-7037 crosses to fk10004,fk10005,fk10007,fk10008,Fk10027,Fk10057,Fk10108, and Frk739. but no Fk10103-2. I am also having a problem with the Mercury web site to order the part, could someone check it for me? Everytime I put in the closest dealer it takes me back to Zip code. Thanks! Bellybuster!!
ljshein
Re: Carb rebuild confusion
www.themarinedoctor.com<br /><br />I had a similar problem with my 125. Bought the wrong thing first and then found TMD. He gave great advice and got me thr correct parts.
Realgun
Belly if TMD aka The Marine doctor tells you something he tells you correctly. He used to post here all the time but he made his own Forums.<br /><br />Do a search on Marine Doctor and you will find thousands of good answers.
