Carb rebuild kit
Rupp
Guys,
My boat is 2 hours away and I know after 22 years the card could use a rebuild. Any of you guys have any idea what Holly card may have come on a 5.0 GL PEFS 4012014293 2000 model?
I suggest you look up the part on volvopentastore.
2 barrel is a holley 2300
4 barrel is either a holley 4150 or 4160
Rupp
Thanks for the info. I found this but how do I cross reference this with the 2300 or 4150/4160?
dubs283
You need to know the carb number stamped into the air horn on the carb, that will give you the proper info for ordering a kit.
FYI, you can order the proper marine kit from holley or order it through a local parts supplier, no need to get from Volvo
by the pic its a 2300 2-barrel. by the engine size its the 500cfm
by googling, there is even an old rebuild threads on iboats
I would buy a holley rebuild kit and not a sierra. without knowing your air-horn number, I would buy this one https://www.holley.com/products/fue...ts/rebuild_kits/marine_renew_kit/parts/703-36
the great thing about holleys:
all bowl gaskets are the same shape, get the blue ones
all metering block gaskets are the same shape, get the blue ones
there are 30cc accelerator diaphragms and 50cc diaphragms
the base gaskets are matched to the throttle body.
the 2300 holley has limited choices, there is a 350 CFM and a 500 CFM so there are only two base gaskets and the kit above has both.
however their kit will come a few extra parts you may or may not need. and your specific power valve may or may not be in the kit.
I tend to buy base gaskets 3 or 4 at a time and a 10-pack of bowl gaskets and I have an assortment of power valves on-hand.
when it comes to rebuild. do not soak the bowls, metering plate or throttle body in simple green cleaner or acid. the parts are made of zinc and will dissolve. us either mineral spirits or a good carb cleaner. do not use bleach on the zinc either.
chase every passage with air and a piece of fishing wire. the acceleration circuit is the first to plug, followed by the idle air bleeds, then the idle circuit
pull the accelerator pump squirter and make sure the check valve (its a carb needle and seat) is free. fuel will varnish this thing in place from sitting
if you have the rubber style of accelerator pump check in the bowl (looks like an orange mushroom) after you pull it thru the bottom of the bowl, snip off the end with a scissors or the long tab will interfere with the float
work over a catch basin. you will drop parts, plus the bowls may have fuel in them, so you want to catch that.
