Carb Rebuild Question
ChrisfromVT
Upon cleaning my middle carb from a '87 115hp, I stripped the screwdriver slot a bit. Does the rebiuld kit include new jets?
Chris1956
Re: Carb Rebuild Question
Normal rebuild kits do not include jets. Jets may be available from Merc.
ChrisfromVT
Will the jet still perform as it should if it;s a little stripped? The orffice didn't get chewed at all...
Chris1956
If the diameter of the hole is unchanged, and the jet is tight in the carb body, it will work just fine. Blow it out with some carb cleaner or compressed air. Make sure the passages are clean.
