Carb rebuild Question?
basbalj288
Hey,
I'm a novice at outboard repair but am learning. I have a 1976 Johnson Seahorse 85 hp. Does anybody know if rebuilding the carbs on this motor is the same process that "Tashasdaddy" mentioned under Engine frequently asked questions??? And if so what is the special tool that I need and does an automotive shop have one?
Thanks for the advice
wilde1j
Re: Carb rebuild Question?
Jet removal tool. You can grind a flat bladed screwdriver to do the same job. TD or someone else has posted what it needs to look like ... basically the two sides are ground parallel and narrow enough to not damage the jet. Maybe someone will post a picture before I find and photograph one of mine.
Not too likely an auto shop would have this.
tashasdaddy
the picture is in the TOP SECRET FILE post. the basics are the same, but you will be working a dual carb, your jets are on each side of the carb, rather than the front. behind screws, and washers.
emdsapmgr
Jet removal tool. 317002. $ 19.97 from your local Bombardier dealer. A really handy tool.
basbalj288
Thanks guys for all the help! I will give it a whirl tonight/ tomorrow morning and let you all know how it goes.
Thanks a bunch,
Matt
_________________________________________________________________
"Boating isn't a pit that you throw your money in.... A pit has a bottom! It's more like a Blackhole!!"
