Hello, I have a few carb rebuild questions that seem to show no results when I try to search for the answers here. At least the way im searching anyways.
1. I have two plugs, like small disks that have been forced fit into holes on the carb body. They sort of remind me of freeze out plugs on a engine block. Should I remove them and how are they put back in. My rebuild kit seems to have included new replacements for them. One is found under the float in the main body, the other is on the very top of the carb when it is in the same position as if mounted to the engine.
2. Do the jets, low and high need to be put back in a cetain way, as in number of turns. Or do you just screw them back down till they are snug?
Thanks everyone.
Thanks everyone.
