carb rebuild
Colinb93rs
omc 3.0 off an 88 doral
rebuilt carb and when I tried to fire it up i got nothing but the venturi spitting gas like mad
any suggestions?
jimmbo
Float, not set correctly, Inlet seat and needle either leaking or missing gasket, heavy float
Lou C
Or a tiny piece of debris holding the needle off the seat. Remove the carb again and hold it upside down. Try blowing thru the fuel inlet, you should not be able to if the needle valve is really sealing off the fuel inlet.
The carb should be a Rochester 2bbl with auto choke.
