Carb. Spring Clips
HenryB
A 1998 Johnson 130 H.P., recently rebuilt carbs, then remembered a caution note in the manual to have the ?spring clips? that hold the needle to the float tab positioned to the left side. I cannot remember if I installed left or right. Any significance to what side the clips should go?
boobie
Re: Carb. Spring Clips
As long as you're on the side you should be okay.
HenryB
Thank you for the come back. Setting the needle and float in place is getting to be a chore for me.
