carb sync question
zindale
hey you guys are great. i have a manual ordered be here in a day or two. question if i open my controls wide open should my carb plates be open fully i have a j115tslecm and my max rpms are only 4700 at 18 mph on 24 ft pontoon. with a 14x13 prop. with tt wont change rpms
imported_lorin
Re: carb sync question
On every motor I've seen, with the controls wide open, the throttle plates are supposed to be perfectly horizontal.
OBJ
You might also want to raise the motor up a hole or two on the transom....this is something you'll have to play with. I've noticed that most toons are terribly over proped. What works on a boat hull don't work on a toon.
zindale
i rebuilt carbs and plugs replaced wires and fuel bulb and installed filter, also did fuel pump rebuild runs better but still 4700-4800 rpms. i noticed that water was shooting up in front of engine where it mounts to transum noticed that engine is hanging down below water line and draggging in water so i moved it up 2 holes now about half inch out of water. havent retried yet .but i think im on to it
