carb. trouble
taz33911
I have a 1962 10hp. evinrude I didn't check the needle valves position [ how far they were turned out] before I took them out to clean the carb.Can anybody help me out with that? I got it to crank up but I have to hold the choke out and keep the throttle wide open or it stalls . might have a bad fuel filter or trash still in the carb maybe? I don't remember where the needle valves were set but it fired up so it can' be far off i hope. I did check the fuel pump it looks like it is clean and working ok . I would be thankful for some help with this. thanks
JB
Re: carb. trouble
Howdy, Taz.<br /><br />Get a manual.<br /><br />For starting point, gently seat both needles. Back out the lo speed about 1-1/4 turn and the hi speed needle about 1-1/2 turn. Once you have her running, fine tune for smooth idle and good torque UNDER LOAD.<br /><br />Good luck. :)
taz33911
Re: carb. trouble
Thanks JB that got it running but now I find one plug is not firing. So now I need to pull the flywheel and check into that . even on one cylinder it sounded ok so maybe it will be worth a little more sweat.carb is good now thanks
taz33911
Re: carb. trouble
If anyone knows how to check the coil with a multimeter that would help out .Hate to buy one and don't really need one.I am getting a puller tomorrow night so I will check back then
