Carb Tuning problems
shroom59
I have a 1958 Hiawatha 7.5 outboard. The model is OM3-7989B. This one is a bit different than the 7987 model in that the carb adjustments are on the inside. There is a big knob that is the high speed and a small one on the bottom that is idle. I turned the high speed out 1.4 turns and then back into 3/4. Now it will run as long as the choke is engaged. This shouldn't be. I have an airline that runs from the bottom intake under and over to a tube on the bottom of the carb. If I take this off the engine runs. Put it back on and try to slow the speed and it dies off. It's not smoking due to cutting back on the oil a bit. I have run a can of Seafoam down the carb slowly. This is the first time the engine has run in 28 years. That line I am talking about spits out air, so I know it's not plugged up. The needles are clean and silver. There is no bowl or glass bowl on this model and getting the bottom of the carb requires some magic! It is so tight in there. Any ideas would be welcomed. I thought perhaps there was suppose to be a baffle or diaphragm on the intake, but the book I have or the sister to this one doesn't indicate one, however it does talk about a gasket. New plugs, a couple of lines replaced. Condensor and points all cleaned up. I do believe the manual said the fast or high speed is factory set. I have it opened right now a little over 3/4. The small one is opened 1/2 from a closed position. A side note, I have a lot of gunk come out the exhaust and I am running non-ethanol gas in it.
F_R
You got me scratching my head a bit. Are you sure it is a 1958? Sounds like you are describing one of the low profile ones. Got some pictures?
shroom59
Its a OM3-7988B. I just went out to read it. The serial number is very hard to read. If I take the intake line off the carb it will run with the high speed knob set at 1/2 turn from the closed position and running with the choke engaged. If i try to close the choke it dies out. But once it is running I can hook the intake line to the carb back on and it sits there at about half speed in the start position and runs like for 10 minutes or more. If I turn out the high speed knob past 3/4 it won't start. the idle speed needle is clean. Its not smoking, but I do have some oil residue in the barrel. My neighbor said after 30 years its probally loaded up with gunk. I have ran over 1/2 a can of seafoam directly in the carb and it runs out the bottom.
shroom59
It may be a 59 or 60, but the model number OM3-7988B is the number. they list 7987 and 7989 but I can't find anything other than a manual on ebay that has my model number on it
F_R
I can't find 7988B either. That's why I suggested a picture. Is there anything unusual about it ie: long shaft or electric start, or?
F_R
The manual you found on e-bay is dated Feb 1960. That gives credibility to my guess that it is a low profile model. Does it have a Tillotson diaphragm carburetor? Still waiting for that picture.
