carb with no manual chocke
fishin-fool
it s a 96 mer 9.9 4 stroke ,i cant find any info on this motor or carb . does anybody heard of this motor and can help :mad:
TOHATSU GURU
Re: carb with no manual chocke
Are you saying that it is missing the choke system or are you complaining about the automatic choke feature?
fishin-fool
it has aoto chock but i cant find anybody that knows this motor . i spent 150.00 to get the carb done run a couple of times then quit :mad:
TOHATSU GURU
Any Mercury dealer should be able to help you. You can go to www.mercurymarine.com to get a list of dealers in your area. As to the specific problem itself...Either the auto-choke isn't working, in which case you buy another one or the carburetor isn't working correctly, in which case you have it cleaned again. You might want to look at your fuel, fuel tank and fuel line before you spend anymore money as one or all may be causing your problem. Keep in mind the smallest bit of trash or water can completely screw up your carburetor. You clean it, the trash screws it up again. Its a vicious cycle.
