carb ?
Bryan76
i have a 7.4 bravo 1 ...I need to know how to adjust the idle air screws @ front of the carb the 2 screws @ the base i beleive its running rich on one side i have black smuck and carbon on one side of my boat and plugs wires are good....thanks
90stingray
Re: carb ?
Do you have vacuum gauge? You can adjust screws for best vacuum... or do the turn it until it stumbles and turn it back method. Either way will work.
mpdive
Re: carb ?
Turn them both in until finger tight and then back out two turns. Like Stingray said you can use a vacuum gauge or you can also use a tach. Adjusting the mixture is not a cure all if there is an underlying problem though.
