muchco
- Joined
- May 10, 2005
- 143
Hi, I am trying to complete a carb job on a 40hp Johnson and I need some assistance. When the carb was removed I noticed that the packing nut (0305507) was loose and spinning freely. I also noticed that the packing (0307583) was in poor shape and one of the packing washers (0306027) was bent in half. Therefore I am inquiring as the the correct installation procedure for the needle valve, packing nut, packings ,packing washers and needle valve bushing, as well as the correct starting point to set the needle (turns in or out)? I have looked at the BRP parts page http://www.evinrude.com/en-US/Accessories/Literature/?popup=true and have a diagram but things still don't quite add up. Any help in this regard would be greatley appreciated. The motor model and serial number is: Model#EL72E Serial#J3626198.
