Been reading quite a bit about having some carbon buildup on pistons throughout this forum. This is a new motor (for me) and I'm giving it a good once-over with the idea of repowering with it next spring. The head gasket had an itty-bitty leak so I decided to remove it and replace. Now that I can see the pistons, I've noticed a carbon buildup on the surface. Seems like the consensus on this board is that it should be removed. I've decarbed my other motor using the protocol suggested here. Not sure how it has worked (haven't looked inside).
Here's what I see in this motor... So the question is how do I remove this carbon buildup? I sprayed it with seafoam, but it doesn't seem to remove it alone. Should I use some form of abrasive? Wire wheel? I can still see the "ridges" on the top of the piston, so I'm worried about scratching it... I can't seem to find any advise for piston cleaning when you have access to it? Can someone advise or point me to a thread I've missed? Thanks!
Tom
Tom
