Carbon problem Sears outboard
Carbonizer
I am having carbon buil-up problem with my sears 1.2HP outboard Model # 369-58230(circa early 60's). After running for about 30 minutes, the spark plug gums up and I have to either replace it or clean it. No easy feat while fishing in a canoe. Here is what I have done so far: I de-carbonized completely the muffler compartment. Also brought it to a small engine mechanic who changed the condenser and had the points checked(they are fine). He also suggested I go to a hotter burning plug, which I did, went from a Champion CJ8 to a CJ6. Gas mixture is recommended at 25:1 in the manual, I am now up to 50:1 and still the problem persists. Any suggestions on rectifying this problem would be greatly appreciated, thanks.
Capt Ron
Re: Carbon problem Sears outboard
Did the mechanic perform a compression check? Low compression will result in incomplete burning of the fuel mixture and oil deposits.
CaptRon
CATransplant
The CJ8 is a hotter plug than the CJ6, so you went the wrong way. If your plugs are fouling, try gapping them to .035. If that still doesn't work, try using a synthetic oil. That could help.
I believe that is a Tanaka-built outboard. Be sure to use oil designed for chainsaws in your fuel mix. I do not know the proper ratio for that model. If there's a tag on the engine, follow that.
I just checked on that engine at www.searspartsdirect.com. It calls for a J17LM spark plug. Try that. You can see a parts blowup for your engine at that site. Just enter your model number. Some parts are available through that site.
steelespike
Its not wrong to try the chainsaw oil but my aftermarket manual says TCW oil my TCW3 oil container recommends use in all sorts of 2 stroke motors from string trimmers to outboards.Ratio is 50:1.Air gap between the coil armature legs and flywheel is .013.You can set it with something like a file card or manilla folder.Point gap is .013.(Not the .020 of 99% of motors).points should just open as M mark on flywheel
lines up with the match mark on crankcase.On carb the jet needle position in throttle slide is set with a clip. Clip should be in the 3rd notch from the top.
Does the motor seem to shudder (4 stroke)dug dug dug when throttle is first opened and perhaps smooth out to a more excited buzz.Or does it tick right off.with an eager buzz.
If it ticks right off smoothly most likely the needle is right.
