Re: carboration Q? 150hp v6
hello<br /> if it will run in the manual prime mode the pump is pumping fuel. otherwise there would be no fuel for primeing, did you physically remove the main jets from the bowls? and was this problem there when you started the carb job ?<br />and are you sure the air jets got put back in the carbs ?
