Carborator Help
Nsteadman14
Any upgrades for 90hp sport jet carborators? Engine # oro46836 or where to buy new idle tunes to install in carborator I killed mine taking the top carborators out 820614 wB 114a322
jerryjerry05
All Dodge, he's working on a 90hp not a 9 :)
Need to know the year or model# serial# ??
You posted.
where to buy new idle tunes to install in carborator"
What's an idle tunes?
Post pics of the carbs.
Redbarron%%
I still don't know what the question is.
What was screwed up on the carb? and how?
Most of the carbs for the 90 are the same, with different jets for different positions and a different bowl for #2 for the enrichment device.
The parts of the manual on the carbs are attached.
What is the problem area?
  • Carb A.pdf
  • Carb B.pdf
Nsteadman14
It’s a 1994 Bayliner Reflexx. Idle Tube is what I meant. Goes straight thru the carborator down to the float bowl and sits at the main jet. I can’t find one so I’m sure I can make one out of something
