CARBS 101
12Footer
This post is meant to be a simple primer to carbs. I won't go into particulars, like manufacturer, jetting, or other high-performance theory here. And I might not have the answer if we did. I just want to explain some of how they work, what goes bad on them most frequently, and how to get you going.Carburators look very complicated all blown-up in those "Exploded views" in the shop manuals. But actually, they are as complicated as assmembling a plastic airplane model, without having to wait for the glue to set before moving-on to "step-35".<br /><br />HOW A CARB WORKS:<br /><br />The carbeurator takes in fuel and mixes it with air, making a fuel-mist. This mist is much more explosive than pure fuel. It then sprays this mist<br />into the combustion top of the cylinder,where the plug detonates the mist.<br />BOOM!<br /><br />DETERMINING IF THE CARB IS THE CULPRIT:<br /><br />First-off avoid adjustemnts. If adjusting a carb is needed,it is needed because something isn't the way it was inside the carb before the problem developed.More on adjustement later.In order for a carb to perform it's vital function , it must be supplied with raw fuel from the tank. No supply ,no end product.In order to supply fuel ,the engine needs a good fuel pump. Most outbaords use a vacumm-powered fuel pump, so it needs compression.So run a compression test.<br />The primer bulb on the fuel hose should firm-up,and no fuel should exit the carb anywhere. The inlet to the carb must be getting fuel, suppllied from the fuel pump. To make sure it is, remove the fuel line where it enters the carb.Some carbs have the fuel pump mounted on them,but even these should have a hose that goes to the carb's bowl. Place this hose into a can and turn-over the engine a few turns..BE CAREFULL that this fuel can't spill ,as if it comes into contact with the ignition or an electric wire, it could become a desaster real fast. Anyway, the fuel should pump into the can in pulses. It's no garauntee all is well with the fuel pump if it does,but we can elliminate it for now as the culprit if you get fuel into the can.No gas in the can means "not a carb problem".<br />If you get fuel,re-attach the hose for now.Pump the primer bulb. Does it firm-up without fuel spilling-out of the carb anywhere? If not, the carb is getting fuel, but is not shutting-ff the supply when the bowl is full..So it overflows, and exits out the overflow hole. This job is suposed to be done by the needle valve being pushed-up by a floating float,and shutting-off the incomming fuel. The needle valve(sometimes called a float valve,samey-same), can be stuck open, or the float has sunk,or is out of adjustment. Take a screwdriver handle,and gently tap the side of the bowl while someone pumps the primer bulb. If the fuel stops, it was the needle valve, and you jarred it loose.<br />At that point, you may be done.But if the needle valve stuck open once, it can stick open again, and at the worst of times! So plan on pulling the carb off anyway, and cleaning it.<br /><br />Turn the engine over, while holding your hand over the throat (the large opening in front). You should feel a slight suction.If you don't, go back to compression,or suspect a stuck or broken reed (RARE).<br />Now pull the plugs.If they are dry, it's a good bet the carb is blocked with trash.<br />It doesn't take much to completely shut off the fuel inside a carb, The fuel must be metered inside a carb so that the engine gets the right amount,and has the right amount of air mixed-in.<br />This is done by jets (small fittings with a precise hole in thier center, to allow only a certain amount of fuel to go thru them), pickup tubes, mixture needles (in two words,adjustable jets) , venturis (small holes like jets) and other tunnels and orafices.These must all be clean and open for the carb to work.
12Footer
Re: CARBS 101
CARB REBUILDING 101;<br />You should not try this without the shop manual.unless you are experianced with this particular carb.This is because all carbs have thier minor and major differences..Leave that tiny spring out that fell on the floor without you seeing it, and your carb is junk.<br />So do yourself a big favour, and get the manual.<br />1. You should have plenty of clean lint-free rags or paper wype-alls handy. Your work area should be as clean as the kitchen table....<br />But listen to her..Carb cleaner and formica do not mix. You must have this stuff, but it's made to desolve things like paint, varnish,rubber particules,vinyl flooring,or whatever else may be plugging the orifices of you carb...It's also quite dangerous to brain cells, so good ventilation is extremely important, regarless of where you tear-into it.<br /><br />2. A tackle box, or other tray with bins , can hold all those little pieces.<br /><br />3. You should also have the carb rebuild kit before starting the teardown.<br />4. when you go after the carb cleaner at the auto store, get some Locktite Blue threadlocker for the final assembly.<br />5. The emulsion-type carb cleaner is great stuff. It comes in a gallon can. But a word of caution..This stuff desolves anything non-metalic. If you stick your carb into this can of cleaner,and soak it overnight, it will desolve all the carbon,varnish and other contaminants...Along with all the plastic, rubber, or other non-metalic parts of your carb!<br />Ungood. But this stuff is great for soaking those screws and tiny metal parts to clean them better than the carb spray can do.<br /><br />Now that you have a clean werk area and all the needed tools and supplies, it's time to remove the carb from the engine.
12Footer
Re: CARBS 101
Future reference post..As the saga continues, I'll post here. I just wanted to reserve the 'spot' in this thread to keep as much of the primer course un interupted.<br />But that said ,and this post posted, feel free to add to this werk in progress,if you have sometihng to add,or something I may have overlooked. <br />It would be a plus ,if any of you have run into certain "wierd" or "carb type-specific" tips or hints on a particular carb.<br />But these first 3 posts are the 101,generic primer.<br />Remove the carb form the engine. Now that you have it in your hand, the first step is to hold it over a coffee can or other conatiner, and drain it. Loosen the carb bowl, but do not remove it yet. Tap the bowl to break the seal provided by the gasket. allow all the gas to drain.<br />mark the adjustments. Turn the ilde mixture screw in,until it just makes contact.DO NOT TIGHTEN.. Count the turns, and write then dow on a piece of paper. At one time,this idle mixture was set perfectly. If it has not been tampered with, it was where it should be on a perfect carb.<br />That done,unscrew the idle mixture screw all the way. Examine the point on the end. It should be evenlt tapered.If it is not, or has any grooves in it, it's toast. Sometimes,a good machinist can re-tip it, but it's best just to find one at a junkyard.<br />Remove the carb bowl{. Be carefull not to bump the float. if you accidently doo, you might change the float level adjustment (the amount of fuel the the bowl holds).<br /><br />YEPBLAZE has a great link there!! It saves me some typin' finger blisters :D <br />Click on his link for more details.
seahorse5
Re: CARBS 101
The April 2002 issue of Bass and Walleye Boats has a good article on carb cleaning.
clanton
Re: CARBS 101
A 6 hole cornbread muffin pan make a good place to put the small parts. I find them at yard sales.
