carbs cleaned
my1stboat1
1988 bayliner. 85 hp force...
took the carbs off to clean completely and install new fuel pump diaphram reassemble carbs and attemtped to performed the sync & link adjustments and also set timing. dont know what the head i did but the clymer book is so vaque i think i made it worse. the engines running good but i nolonger have throttle in reverse... Also the cylmer book says to set throttle to wide open my boat wont allow me to put it in wot unless the boats running...
Confused.. Any help
maxum_man
Re: carbs cleaned
Pull out on the control handle (or push little button in at the center) and push control forward. That is WOT.
roscoe
Re: carbs cleaned
final adjustments need to be made with the motor running, in the water.
john from md
Re: carbs cleaned
WOT is not when the handle is pulled out and pushed forward. This position is the fast idle for cold start.
Go back to the Clymer manual and start over. Start from where you remove the cable and align the two marks on the carb pickup with the throttle bellcrank. Don't cut any corners and take your time.
Now, that said, rigging the carb/timing sync does not affect forward or reverse. Shifting is controlled by the other cable that runs next to the trottle cable. It sounds like somehow you misadjusted this as, with the engine off, you should be able to move the throttle lever from WOT forward to Reverse with no problem.
John
