davejohnson
- Joined
- Sep 4, 2004
- 26
I was having some problems at low RPM's with my '78 inline six. Stalling. It would idle very nicely forever, but stall when I nudged the throttle forward. Thought it was bad spark or fuel delivery. So, my last effort was to try and adjust the idle upward a bit.<br /><br />Throttle cable and gear cable go into the motor through a rubber boot on the port side. There's a threaded bit that passes through a brass sort of barrel, held immobile by a plastic clip. Undid the clip, spun the threaded barrel three or four times clockwise, reseated the brass parts, and the idle came up a bit. Now, no stalls around the dock, and it putters in the no-wake area very nicely.<br /><br />Question: my thought all along was that the carbs were gummy. Is it true that if the motor will idle, then the ports are clear? Seems logical, but this motor defies logic more often than not.<br /><br />Thanks,<br />Dave
