carbs flooding
catfish
hello i have a 70hp merc 84-86 year that has been idle for a year the problem i have is the bottom carb is spitting fuel i replaced the float. and the needle and seat. i also blew out all the passages with carb <br />cleaner is there something that i may have missed?
Ben Konopacky
Re: carbs flooding
Did you adj. the float? if its blow back from the carb,its possable to have bent/broken reeds.
catfish
Re: carbs flooding
float is new adjusted to new specs with float. if the choke passage is blocked would that flood carb
Barnacle_Bill
Re: carbs flooding
If you are sure you rebuilt the carb correctly, like Ben said, that is a symptom of a bad reed,
catfish
Re: carbs flooding
wait brain poot. i decribed the problem incorrectly the carb is not spitting fuel out the carb fuel is spitting out of the venturi and nozzle sorry i was up late lastnight
