Hey all,
I decided to repower my boat from an 83 crossflow, to a 94 looper (yeah, I'm poor what can I say).
The looper is a 1994 200hp ocean pro, E200TXERK. 110 (ish)PSI compression on all 6.
When I got it, it wouldn't start at all, the guy told me it had a "carb" problem, so as a precaution, I decided to rebuild the carbs (lost too many pistons because of bad carbs).
When I pulled the carbs, all 6 of them were absolutely slam full of STRAIGHT 2-stroke oil. (I mean straight oil, not one bit of gas). (hence why it wouldn't start, hard to run without any gas). The oil was even a little thick like it had been sitting in them a while. I have no idea how they could have been filled with oil instead of mixed fuel/oil?
Anyway, I went ahead and rebuilt all 6 carbs, and the primer, and hooked everything back up (including the VRO/Oil tank). Started it, and the motor fired right up, no problem. Started immediately, and idled great. I Ran it just a few mins because I wanted to do the waterpump/tstats (also precautionary) as well, but seemed fine for the few mins I ran it.
I let it sit just like 2-3 weeks on a stand in my garage, (everything still hooked up), and decided to fire it up again before I started on the water pump... well it wouldn't start... crank, crank, crank, nothing. Hit it with some pre-mix I sprayed into the carb throats, and it sputtered a bit... after doing that a few times, it fired up, but it smoked like holy hell. It looked like I was fogging for mosquitos. After a min or two of this, it cleared up and seemed to be running ok again...(normal small amount of smoke).
I did some research, and asked around, and someone told me that there is a check-valve in the VRO pump that is probably bad, and letting oil into the fuel side. this would have filled the primer up with oil first (hence it not getting the fuel squirted when choking it to start, so why it was hard to start the second time around) and also why it smoked so bad. I just don't see how it can do this while sitting, when the oil tank is way lower than the engine, the oil tank is on the bottom of the stand (how does it siphon UP oil?)
I checked, and the VRO tank, had hardly any oil used, but again,(1/4" drop in the 1.8gal tank) I have only idled the motor maybe 10 mins. since I got it running and haven't used a lot of fuel yet... so I am not 100% sure if this(bad oil valve) is the case...
My questions:
1. Does anyone have any other suggestions on what I should look for as being the problem? or
2. should I just disconnect the VRO, and run pre-mix? (Yes I know that's a HUGE debate, some say yes, some say no), but I don't have the 500bucks for a new VRO pump right now. (I am already used to pre-mixing on the 83', and the tank is already full of pre-mix anyway).
I am obviously leaning towards just disconnecting it... but want to be sure that there isn't another problem I should be aware of.
Thanks
My questions:
Thanks
