carbs need to be in sink
licketdsplit756
115 hp johnson 1985 after rebuilding the carbs. x 2 do they need to be in ? i know i cant spell this word? do they need to be sycrinized so as to run good and even flow. is it possible to do it at home?
Barnacle_Bill
Re: carbs need to be in sink
Your manual would give you the entire link & sync procedure. As far as the carbs are concerned the objective is to be sure all the butterflys are completely closed with throttle in idle position and they all open evenly.
licketdsplit756
Yes Bhile Carbs Open And Close Together. Was More Concerned About The Jets. Are They Adjustable. Air Jet 1.5 Turns Gas Jet 1 Turn.. That Kinda Thing..or Are They Preset. And Dont Have To Do No Adjusting. Just Screw Them In
licketdsplit756
DONT HAVE A MANUAL. REKON I BETTER INVEST IN ONE.:p WHERE IS A GOOD PLACE TO FIND THE ORIGINAL MANUAL FOR THIS MOTOR JII5TLCOS 1985 JOHNSON 115 HP OB.
jtexas
try marineengine.com and/or kencook.com
also the schematic drawings and parts catalogues are available online here:
http://epc.brp.com/default.aspx?brands=ej&lang=E
I know it says evinrude, but johnson is there too.
also at ishopmarine.com
