Carbs switch?? 1986 xp150 to 1977 175??
WillyBWright
Re: Carbs switch?? 1986 xp150 to 1977 175??
The 77 definately has choke plates. The 86 probably uses a primer instead.
throwback2332
Well can i take the intake off the 1986 xp150 and put on the 1977 175 along with the choke system. then swap carbs??
jims3000
i would check with a qualified mechanic i dont think the jets in the carbs on the 150 would give the 175 enough fuel to run right.
Dhadley
The carbs will work just fine as is. No rejetting needed. You don't need to change the intake manifold. Just replace the choke solenoid with a primer solenoid. Great upgrade!
throwback2332
Replaced the carbs from the 1986 xp150 to the 1977 175 ran great had to do a little thinking on fuel hose routing and choke. Used the primer choke.
Thanks
Dhadley
Glad it worked! That's a common upgrade these days.
throwback2332
The 86 150 carbs are bigger than the 77 175. Correct. The orfice calls for
58c on the 77, but with the 1/16'' bigger carbs which had 61c orfice will this be ok?? i figured my air, more fuel will be need plus will run a tad bit rich. Better than lean.
Dhadley
The carbs are calibrated for the amount of air flowing thru them. Jets are only part of the calibration. For stock rpm the original jets will be fine.
