kfa4303
Banned
- Joined
- Sep 17, 2010
- 6,094
Hi all. So I've been tinkering with a 3 hp Gamefisher. After getting new s/plug, 50:1 gas, new lower unit oil and general refurbishing I took the little motor out. It ran ok for a bit, but then about every 30 sec. - 1 min. it would then bog down and cut out no matter what speed I was traveling. However, it would always start right back up with one pull.
So I brought it home and rebuilt the carb b/c I figured it was a fuel issue. Thankfully, the carb wasn't dirty, all needles and jets were in great shape. So, I put everything back together (no leftover bits and pieces or anything
) and started it right up. Ran better than ever, smooth as butter, so obviously cleaning the carb helped. I could even rev to high rpm in tank and all seemed well. However, after letting it idle for 5-10 min in tank it cut out again:/
I'm 99% sure the fuel system is ok, so I'm thinking condensers. Am I right? I also noticed that the pull start on top of motor is quite warm, which also made me think the condensers are getting too hot beneath the flywheel. Sorry if I making dumb guesses, it's just that I've done just about everything else I can think to do.
