Carbs
Simple_Man
Over the fourth I found out I have mis-matched carbs on my 1987 85HP. I this a big deal? Also if I were to look for a "set" which model has the screw in seats ect, and can I use them on my motor.
Jiggz
Can you post pics? Are you referring to the part numbers of each carb not being the same or the physical appearance of each carb?
Simple_Man
the float needles are different sizes and use different style seats they work but I would like to find a set with the screw in air mixture seats will get pics as soon as i take them off
Simple_Man
after research I believe I have carbs from an 856x7a and a 856x7b. Slightly different but the same. I just have to remember that. Thanks anyway Jiggz
Simple_Man
ugh replaced the float needle and seat with the correct one now i cant get it adjusted. either wont seat and leaks fuel from the overflow and jet on the side. or it starves for fuel. top carb markings are 631061 WE9-1 11/86 middle carb 632061-1 WE18-2 12/86 bottom carb 632061-1 WE18-2 1/87. I am assuming the PO swaped the top carb I would like to find a set with the better float needle and seat, because the rubber seat with the retainer clip sucks. Any explanation of the part #"s would be helpfull in my srarch for a carb set
