Peter Karaganis
- Joined
- Jun 10, 2001
- 5
<br /><br />I'll check that out, but I don't think that's it because it was just myself and one other person in the boat. It wouldn't even plane out. He had two props w/ the boat. One was pitched differently than the other, but I tried them both w/ pretty much the same result.<br /><br />Originally posted by SeaBear:<br />As you have just bought this boat I'm just wondering if it's overpropped? What is the max RPM it will reach and at what throttle %? If it sounds as if it's 'gasping' for air after that point without missing [as you say] I would just double check the prop is correct for the boat and load? By load I mean if you have 8 people aboard and the previous owner used to have 2 it can make a big difference especially if the boat won't plane [the point after the boat's bow drops and the wake flattens] ... like driving your Jeep up a hill in a high gear with your foot flat to the boards and it doesn't gain speed?
<br /><br />I tried adjusting the fuel/air mixture w/ little or no success, and I did check the venting. I guess that I'll order the rebuild kit. It's only about $30.00, and go from there. I haven't put a pressure tester on the fuel line, but there is a clear inline filter between the fuel tank and the pump. It shows to be moving pretty good through there, so I don't think it's the tank.<br /><br />Thanks for all of the advice everyone! I'll let you know how the rebuild goes on the carb.<br /><br />------------------Originally posted by ODDD1:<br />Peter, the holley 2 barrel carbs volvo used on these motors were jetted VERY lean.....had them lean popping away while the boat is on plane! an increase in main jetting will help........
