carburation problems????
paraleah
1996 Evinrude 225hp v-6 Carburated outboard. The top two cylinder spark plugs keep fouling after 3 to 4 hours of 3/4 throttle. I am not trolling at lower speeds. The plugs have a hard charcol crystalized residue on the electrode. the other four plugs look normal. i just replaced the stator and had the spark and voltage checked. the compression is good on each cylinder. do you think the top two carbs are running rich? if so is the an adjustment on the front of the carb?
JB
Re: carburation problems????
Hi, Paraleah.<br /><br />I would investigate the float level adjustment on the top carb(s). If it is set too high it couold make those cylinders run rich.<br /><br />Good luck. :)
willxuout
JB,<br /><br />Thanks for the advice. I'll let you know if that was the solution.<br /><br />paraleah
