carburator spring needed
petewv
I have a 1965 9.8 hp Mercury outboard. motor. Were can I get the choke spring that goes from the choke shutter to the lever. . I looked on the iboats .com web site it said N.A for the spring.
is it normal for there to be a small gap between the choke shutter and the carburetor , when the shutter is closed ? It is .035 of a inch. Would that cause the motor to be hard to start.
I could put a small washer behind the bolt to get it to close against the throat of the carburetor if it needs to close tight.
Silvertip
Re: carburator spring needed
Unless the choke closes fully it is not choking fully.
