carburator
bertos
i'm getting fuel in my oil can anyone tell me how to take it off the motor you have the 4 bolts. But what whats the is connected to it i just dont wont to screw this up theres the fuel line but what about everything else . I have a 350 chevy omc thanks for you help
Re: carburator
Ayuh,... No disrespect intended,...
But,...
If you're not comfortable taking the carb off the motor,...
There's no way in 'ell you're gonna Rebuild that carb....
This is a Rochester 4bbl. ain't it,..??
Are you getting Gas in the oil when Running,..?? Or just when it sits awhile,..??
a70eliminator
Re: carburator
Righty tighty, lefty goosey, there's not much to screw up taking off a carbur-e-tor other than dropping a nut down into the intake manifold and having to perform emregency surgery.
180shabah
Re: carburator
Are you sure the fuel problem is the carb and not the fuel pump?
Jello Shot
Re: carburator
I will bet that the diaphram on the fuel pump is bad. I would replace the fuel pump, change the oil, replace the filters and see if the problem still exists.
180shabah
Re: carburator
I would determine the cause before I just through $100+/- at it.
There is a sticky at the top "Adults Only" inside there is a link for testing the fuel system. Great resource.
