On my 1999 Force 50hp, the bowl floods in idle. It is fine as long as the throttle is open even a little. When I looked at the float seal, it was flat, and didn't appear it would be very effective at stopping the flow of fuel. Should that seal be contoured to make a tighter seal on the intake needle? Also, the little metal piece that had the seal on it I think was rivited to the plastic float. When I look at pictures of replacement floats, they do not even have the metal piece on there. It that a separate part? Thanks
