Carburetor float
Kgreenwood
Arrgggg I got a 1968 65hp Johnson
Vxb14b and I can't find a float for it need some help it runs good but got gas pouring out of the carb vent.is there any type of replacement out there brass or cork some advice would be great
Kgreenwood
Re: Carburetor floay
No way lol it was there the whole time I've been looking in carb kits not separate thanks alot
Daviet
You're welcome, glad I could help you out.
Kgreenwood
Now what about fuel mixture and the best rpm range to operate it at
I'm using 24-1 right now to test it and all that fun stuff. Also this motor has a broken prop witch I'm going to order. this motor is going On a 16' Starcraft it came off a 14'4" boat I though about using a 10 inch prop with a 11pitch that what was on it.will this hurt the motor cuz it's a bigger boat?
Daviet
Fuel mixture should be 50:1. The best way to prop the engine to the boat is by using a tach. If you arn't turning the proper RPM you will not devlope the proper horse power. Usually when you go to a bigger, heaver boat from a smaller, lighter one you use a smaller prop.
