Carburetor Obsolete need help finding correct one 3.5hp Mercury
Ryanc236
I have checked the parts catalog on the Mercury website which say the carburetor is no longer available. The serial number is 0R328329 and the model number is 1-F03201H K, please help I don't know which one to purchase. I soaked the carburetor overnight blew the jets out and the float is working fine I have given up on this carburetor. There seems to be plenty of fuel coming out of the fuel line to the carburetor. Once the new carburetor is installed I will also install a fuel filter in the line. I just purchased this motor cheap it had bad gas in it. It will start only start for a second if carburetor cleaner is sprayed directly in to the air intake. Thnk you for any help.
run a fine wire thru all the passages
no need to buy a carb, properly clean the one you have.
Ryanc236
I have run a wire through it, I'm sure I'm missing something I've all but given up on the carb...
