fisherman34
- Joined
- Sep 4, 2008
- 8
Recent purchase motor was slow starting but seemed to run ok after starting. I put in a kit on the 3 carbs.When trying to start the motor it runs at a very high speed. I tried to adjust the low speed valve , but it did not seem to have any effect.
I was confused ( did not note exact fuel lines connections before removing )From fuel pump there were Tees that went to each carburetor and primer unit. The smaller lines I ran from carb. to primer unit on bottom carb., then the primer unit to middle carb. then to top carb.
Thanks for any advice.
fisherman34
fisherman34
