Carburetor to lean??????
twn827
Hello I have a question and am hoping to get some answers. i have a 1992 volvopenta 431 which is burning spark plugs. after talking to someone they said the carburetor could be running to lean and causing the plugs to overheat. Anyone have any thoughts or ideas?
ChrisCraftJohnny
Re: Carburetor to lean??????
Have you inspected a spark plug yet? If it's very very white, you are running lean.
Also a lean condition will produce sputtering a high RPM's and possibly some detonation.
Johnny
twn827
thanks. it does sputter and backfire at wot. it also seems like it is missing at wot.
Alpheus
Then it is most definitely running to lean. Check your fuel filters and fuel pressure. I would suggest you STOP running it in this condition. You run a very high risk of causing severe engine damage...
John_S
If you have signs of burning/melting sparkplugs, the same is happening to your pistons. As others have stated, it is most likely a lean carb condition. Once that has been found and fixed, check your base timing and advance.
bigdan1
hope for you it`s not too late already ...
had a cutomer that piston no 3 had a hole in midlle by running too lean .
too lean = very high combustion chamber temps
twn827
thanks for the info. i already stopped running it and did not go to far since the new carb was installed. i already had the carb adjusted and new plugs in. also put a new fuel filter on also. anything else?
Aloysius
Too advanced timing will cause a similar problem. remember, ethanol laced fuel causes a lean condition in a carbureted engine, since the ethanol is an oxydizer!
twn827
thanks for the info. had the carburetor adjusted and took it out for a 45 minute run. there was no backfiring or missing at all. no sounds from the engine so i do not think it burnt any pistons. HOWEVER: after running it we docked to get the trailer. once we docked the engine would not start up. it tried to turn over and then just a clicking sound. any ideas as to if this is the starter or perhaps just the solenoid??
Alpheus
Start another thread or do a search...
6meter
Just a little FYI, lean running carbs cannot be fixed from outside the carb.
Danny Mc
If you have a new carb it may have the wrong jets in it.
As 6meter says you can't adjust rich or lean cond from out side the carb.
a70eliminator
He said the carb was adjusted and now it runs good, so however they adjusted it must have worked.
bruceb58
has nothing to do with being an oxidizer and has everything to do with a different stoichiometry but at ethanol less than 10% its not a critical difference to even worry about.
