Carburetors hose stems
David2021
Hello all.
1991 Evinrude 50hp VRO
I’m cleaning out my carbs and I labeled the hoses to their hoses the same as I did on the carb. However, I assume the gas ate through the marker since nothing is on the hoses now. On top of that, I’m short a hose now? I removed my VRO and am installing a fuel pump and mixing my own fuel. I’m putting a 3 piece manifold off of my fuel line. So one hose from the manifold and one of the primer hoses will go yo each carb but now I’m in a loop cuz there aren’t any other hoses and I can’t remember 100% if there was even a hose in all 3.
Does anyone know if I should have 3 hoses there and if so where does the 3rd hose stem lead to? The hose from the fuel line manifold will go to #1, and the hose from the primer solenoid will go to #2 but I’m stumped on #3.
tphoyt
Can’t say for sure but maybe my thought will jog your memory. #1 primer #2 case vent #3 fuel in from pump.
