Re: Carburettor core plugs
My opinion is that, if the core plugs come with the kit, why not use them? They will allow you to clean in areas that may remain dirty and clogged otherwise. <br /><br />They are easy to remove... Carefully drill a small hole in the plug (don't too deep, just enough to get through the plug). Then insert a small scredriver and pry out. To install... I like to coat the edge of the plug with a thin coating of Sealer 2000 or similar sealer (I suppose most fuel resistant sealers would work). Then install the plug in its bore with the convex radius facing outward. They apply a few modest blows on the face of the plug with a flat punch until it has expanded securely in the bore.
