Carby float adjustment
scottcmb
Hy Rodbolt, i have a 1991 225hp TXRP 90 deg V6.
When adjusting the float level to the specified 16mm plus or minus 0.5mm, is the measurement taken with float bowl gasket in place? ( as the gasket has to be installed first before the float and needle valve assembly is installed) or assemble without gasket, do the float adjustment and then dissassemble float to install gasket to reassemble the bowl.
Cheers:):)
