Carpet 87 Bayliner
BogFaerie
Hi Folks,<br />Just purchased an 24' 1987 Bayliner Ciera with my boyfriend. The previous owner let it go (BADLY), and the interior really needs work. The floor is rotted out in one area. I was looking for advice on how to replace the carpet in the cabin. I can't tell yet, but it looks like the carpet goes under some of the storage areas. There are also some challenging curves and corners. The cabin is fully enclosed and shouldn't see much weather - so I was wondering if the stuff from Home Depot or Lowes would be OK. Also, anyone know how to get those decorative padded fabric panels off the cabin walls for reupholstering? <br />Any books you could recommend for rehabbing the interior? This is my first boat and I'd like to do as much on my own as possible. Not afraid of getting dirty. Thanks for any advice....
Wimperdink
Re: Carpet 87 Bayliner
Bump.. I was hoping someone would chime in on this one too as I need a good carpet job and have an 85 bayliner capri that has all kinds of funky angles too. :)
thesketh
I just recarpeted a 1983 bayliner capri. i did a lot of research before starting and hope this helps.<br />First i stripped the entire upholstry out of the boat..<br />Bayliner uses carpet everywhere, and the carpet had many cut pieces laid together.. So I removed each piece, took a digital picture of where it came from as they came out and wrote the location down on the back of every piece. (this helps when the project wears on and you need a refrence) <br />I had to rebuild the ski locker area, and repair areas of the deck.<br />I glued (gorilla waterproof) and stainless steel screwed new supports for the ski locker and overlaped them by 5 inches all the way around under the deck to get a good bite as so the pressure of the cantilever edges don't pullout. (marine grade plywood)<br /><br /> I went to the local marine store and purchased a two part penatrating epoxy.. there are several names.(get rot, west marine brand, rot doctor). basicly you drill a bunch of 1/8 in holes in your deck,(stoping before you drill all the way thru) and inject the epoxy into the holes to strength the wood. I then applied fiberglass cloth on the deck and coated the entire deck with several layers of resin.<br /><br />I wire brushed the entire deck, sides and gunwalls with an electric hand grinder with wirebrush attachment. <br />Everyone told me do not use the home depot/lowes indoor outdoor carpet,as it is not made for constant water and mildew..<br />I used marine grade carpet and marine grade glue, you put the glue on with a trowel.. (approx 2 and half gallons were used).<br />Each piece of old carpet was a pattern for the new piece. I placed the new carpet upside down on the driveway, and the old piece on top and marked it with a sharpie marker. Since the marker is traced on the outside edge, it makes each piece a little larger. I used a carpet knife to cut the piece out, and put on the newly glued section.. (one section at a time) Since, i was new at this a did some overlaping, until i was comfortable in makeing some of the more intricate cuts (near the bow and the front seating areas.<br />I took my time, and had my 16 y/o son help me. I stopped when i got tired, (as i tend to lose patience quickly)<br />It was a longer project than i expected, but i did i right so i wouldn't have to do it again in a year or so.. I have gotten lots of complements on how well it turned out..Plus my wife will now ride in the boat. <br />the carpet and the glue was around $500.. but the boat shops wanted $1500 just to carpet it and that did not include rebuilding the deck or ski locker supports and lid.<br />I had never fiberglassed before so it was all new, but it was really pretty simple. Since its all coverd with carpet it didn't have to be pretty..<br />We just got back from a week a lake mojive and all went well. I had six 20 y/o's and the rest of my family wakeboarding and tubing and it held up without any snags. <br />any way i hope this helps.
BogFaerie
Thanks, Shovelhead. I got down in there yesterday with a screwdriver, putty knife, and pry bar and started snooping. Pulled up the carpet at the bottom of the stairs and there's a 2' round hole in the fiberglass. The glass is also cracked extending for another 3' through the center of the cabin. The plywood the glass is laid on is completely rotted. It's beyond repairing with injected epoxy. It also looks like the cabinetry sits on top of the old carpet...doesn't mean we have to redo it the same way. The cabinets seem to be attached with L brackets - not hard to pull out. I hear ya about keeping the old pieces for pattern tracing. <br />Oh, and those stupid padded panels? They were screwed on from the OUTSIDE. The screw heads were hidden under a thin bumper strip. The new ones are going up with velcro. I'm going to rebuild them out of luwan (sp?) since the old ones are made of thick plywood and rotted out. <br />We're going back today to trace out the floor. Probably going to build a few new stringers and drop a piece of coated marine plywood in there, then cover it with carpet. Part of the bottom step needs to be rebuilt, too. I'll probably use the indoor outdoor carpet since the cabin is fully enclosed. It's just us and the dog, so it shouldn't get too wet down there. Unlike the previous owner, we're planning on taking care of the boat once it's done. This is going to be one heck of a project. A lot of grunt work, but it'll be worth it. I'll share some pictures soon.
