Re: Carpet Question
How likely are you to want to take the carpet up again?<br />If you'll need to take it up then it may be better to cut the carpet to fit, so you don't need to remove the seats to lift the carpet.<br />On the other hand if you're unikely to need to lift the carpet, or if the seats are easily removed, then laying the carpet and putting the seats over it is much easier!<br />I guess what I'm saying is there's really no right or wrong way, just whatever's convenient for you.<br />The only exception to this might be if the seat bases have to be sealed to the deck for some reason, floatation etc..., in which case you'd have to trim the carpet to fit the seats
